[GRASS5] r.support
Brad Douglas
rez at touchofmadness.com
Fri Apr 15 12:58:30 EDT 2005
On Fri, 2005-04-15 at 10:36 +0200, Markus Neteler wrote:
> On Thu, Apr 14, 2005 at 09:22:57PM -0700, Brad Douglas wrote:
> > Let me know if you are still having trouble. I believe it's a null
> > dereference in G__find_file(). I just pointed a pointer to it, which
> > should stop the segfault.
> > I've tried it again and again with all option combinations and I still
> > fail to crash. Odd.
> It still crashed, but I have applied this fix to CVS:
> front.c:
> /* Parse command-line options */
> - if (G_parser(argc, argv)) {
> - G_warning(_("Unable to parse arguments."));
> - G_usage();
> + if (G_parser(argc,argv))
> + exit(1);
> I remember darkly that G_usage() should not be used any more.
> The old code was from 5.x...
G_usage() is depreciated? Even so, the above changes should not fix the
module.
Did G_parser() somehow succeed without command-line arguments before
this patch was applied (and why for you and not for me?)? That would
explain how G__find_file() was segfaulting on a null pointer
dereference.
This is very strange.
Brad Douglas <rez at touchofmadness.com>
