[GRASS5] db.connect and auto-creation of dbf/ directory
Markus Neteler
neteler at itc.it
Thu Apr 21 09:27:20 EDT 2005
when using db.connect to define in a new mapset the DB connection,
I face following non-feature:
db.connect driver=dbf database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
db.connect -p
driver:dbf
database:$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
schema:(null)
group:(null)
So far so nice. But:
g.copy vect=ammprv,pat_ammprv
COPY [ammprv at PERMANENT] to current mapset as [pat_ammprv]
DBMI-DBF driver error:
Cannot open dbf database: /ssi0/ssi/neteler/grassdata/pat/export/dbf/
WARNING: Cannot open database '/ssi0/ssi/neteler/grassdata/pat/export/dbf/'
no database is open
WARNING: Cannot copy table
WARNING: Cannot copy ammprv at PERMANENT to current mapset as pat_ammprv
Yes, I know, that the user has to create this directory first. But
this could also be done by the program.
So, where to apply a code modification:
- db.connect - when using dbf driver?
- g.copy/g.rename - when using dbf driver ?
Markus
