[GRASS5] d.vect disp=cat|attr where=
Martin Landa
landa at gama.fsv.cvut.cz
Fri Apr 22 13:04:55 EDT 2005
Hi all,
I have problem with using d.vect.
Map contains centroid category number 608 and 70 (one layer).
cat | typppd_kod
70 | 304
608 | 18
I would like to display category number or attribute based on where condition.
For example
d.vect kml_hp disp=shape,cat llaye=84 where="typppd_kod=304" lay=84
should have display only category 70. But d.vect doesn't work on this way. The both categories
(so 608/70) are displayed.
I have tried to prepare simple patch for d.vect. I hope that it could be useful and maybe added
to CVS tree.
Best regards,
Martin
Martin Landa <landa at gama.fsv.cvut.cz> * http://gama.fsv.cvut.cz/~landa *
CTU Prague, Faculty of Civil Engineering, Czech Republic
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050422/69b4ae7c/d.vect_patch.tar.obj
