[GRASS5] [bug #3160] (grass) r.support build error
    Glynn Clements
    glynn at gclements.plus.com
    Fri Apr 22 18:36:22 EDT 2005
Maciek Sieczka wrote:
> > Sorry; I should have suggested:
> > LC_ALL=C make
> Now it speaks English:
> modcats
> make[1]: Entering directory
> `/home/pingwin/src/grass6/raster/r.support/modcats'
> Makefile:15: warning: overriding commands for target `htmletc1'
> ../../../include/Make/Rules.make:94: warning: ignoring old commands for
> target `htmletc1'
> gcc -s -pipe -D_FILE_OFFSET_BITS=64 -Wl,--export-dynamic -L/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib
>         -DPACKAGE=\""grassmods"\" -o
> /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcats
> OBJ.i686-pc-linux-gnu/modcats.o -lgrass_gis -lgrass_datetime -lz    -lgrass_edit
>  -lm  -lz
> /usr/bin/ld: warning: libgrass_vask.so, needed by
> /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so, not
> found (try using -rpath or -rpath-link)
Right. As it says, we should be using -rpath-link. I thought that we
were.
The correct switches are already present in LD_SEARCH_FLAGS, but we
don't appear to be using that.
AFAICT, the way that other modules get around this is to explicitly
add $(VASKLIB) to the link command in the Makefile.
