[GRASS5] [bug #3160] (grass) r.support build error
Markus Neteler
neteler at itc.it
Wed Apr 27 11:34:36 EDT 2005
On Fri, Apr 22, 2005 at 11:36:22PM +0100, Glynn Clements wrote:
> Maciek Sieczka wrote:
> > /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcats
> > OBJ.i686-pc-linux-gnu/modcats.o -lgrass_gis -lgrass_datetime -lz -lgrass_edit
> > -lm -lz
> > /usr/bin/ld: warning: libgrass_vask.so, needed by
> > /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so, not
> > found (try using -rpath or -rpath-link)
> Right. As it says, we should be using -rpath-link. I thought that we
> were.
> The correct switches are already present in LD_SEARCH_FLAGS, but we
> don't appear to be using that.
... if you know how to fix that, please apply to the CVS.
> AFAICT, the way that other modules get around this is to explicitly
> add $(VASKLIB) to the link command in the Makefile.
Thanks
Markus
