[GRASS5] [bug #3184] (grass) db.execute: create, add: catch names too long
Request Tracker
grass-bugs at intevation.de
Mon Apr 25 18:29:36 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3184
$ echo 'create table zz (cat int, axis int, contour int, \
x double, y double, segmentlength double, linelength double)'|db.execute
This should be caught that segmentlength is too long a name, and exit $?=1.
P.S, no matter what I click in d.path, it will not let me proceed from
choosing "from":
$ d.path z6
L: from M: to R: quit
Node 4: 233530.038151 2680135.141840
Node 1: 233016.843750 2679852.947917
On http://grass.itc.it/grass57/tutorial/network.html, it says:
"Reachability of Schools (find better name)".
Maybe use 'Distance bands from selected schools'.
I had to use cat \> 1 in this makefile, else v.iso.net Segmentation faults:
roads:
echo CREATE TABLE $@ \(cat int,fare double,distance \
double\)|db.execute
v.db.connect map=b8 table=$@
v.to.db map=b8 option=cat
# echo UPDATE $@ SET fare=300|db.execute #except axis
echo UPDATE $@ SET fare=300 where cat \> 1|db.execute
iso:
v.net.iso input=b8 output=$@ ccats=1 \
costs=$$(seq -s, 100 100 2000) afcolumn=fare
--- Headers Follow ---
>From jidanni at jidanni.org Tue Apr 26 00:29:36 2005
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 3707C1005BA
for <grass-bugs at lists.intevation.de>; Tue, 26 Apr 2005 00:29:36 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
by mail.intevation.de (Postfix) with ESMTP id CB87F36CDC
for <grass-bugs at lists.intevation.de>; Tue, 26 Apr 2005 00:29:35 +0200 (CEST)
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
by mail.intevation.de (Postfix) with ESMTP id 2867136CDB
for <grass-bugs at intevation.de>; Tue, 26 Apr 2005 00:29:35 +0200 (CEST)
Received: from tc218-187-78-84.2-4.dynamic.apol.com.tw ([218.187.78.84]:32883 helo=jidanni1)
by frodo.hserus.net with esmtpsa
(Cipher TLSv1:AES256-SHA:256) (Exim 4.50 #1)
id 1DQC4z-000J9r-JR by authid <jidanni> with plain
for <grass-bugs at intevation.de>; Tue, 26 Apr 2005 03:59:32 +0530
To: grass-bugs at intevation.de
Subject: db.execute: create, add: catch names too long
Date: Tue, 26 Apr 2005 01:21:37 +0800
Message-ID: <87fyxe3h7i.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.5 tagged_above=-999.0 required=3.0 tests=BAYES_00,
DATE_IN_PAST_03_06
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
