[GRASS5] [bug #3188] (grass) v.net.iso: some roads cost, others
distance: sorry
Radim Blazek
blazek at itc.it
Wed Apr 27 02:55:39 EDT 2005
Just for others, so that they don't get wrong impression.
If you need to use costs you can calculate them in the database (use
postgres). In this special case something like:
v.to.db option=length
echo "update my set cost = length where costs is null" | db.execute.
Radim
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3188
> v.net.iso afcolumn=cost allows us to use a cost instead of a distance
> for segments.
> OK, what if on some of my roads I want to use cost, and some I want to
> use distance?
> Surprise surprise, nope. It's either all cost, all distance, or close
> the road with -1.
> Forget about DELETE FROM table WHERE cat =
> road_I_want_measured_by_distance, v.net.iso will go nuts.
> OK, then what are you going to set its value to in the table, -1? 0?
> -1 is for closed roads. 0 is for 0 cost roads.
> Nope. "The software engineers never considered this possibility."!!!
> The solution for now would be: if the row is not found in the table,
> then measure distance. Better would be -2: use distance.
> --- Headers Follow ---
>>From jidanni at jidanni.org Wed Apr 27 00:57:51 2005
> Return-Path: <jidanni at jidanni.org>
> Delivered-To: grass-bugs at lists.intevation.de
> Received: from mail.intevation.de (aktaia [212.95.126.10])
> by lists.intevation.de (Postfix) with ESMTP id 602A5101EE8
> for <grass-bugs at lists.intevation.de>; Wed, 27 Apr 2005 00:57:51 +0200 (CEST)
> Received: from localhost (localhost [127.0.0.1])
> by mail.intevation.de (Postfix) with ESMTP id 320BB36CDC
> Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
> by mail.intevation.de (Postfix) with ESMTP id CE4ED36CDA
> for <grass-bugs at intevation.de>; Wed, 27 Apr 2005 00:57:49 +0200 (CEST)
> Received: from tc218-187-77-5.2-4.dynamic.apol.com.tw ([218.187.77.5]:32817 helo=jidanni1)
> by frodo.hserus.net with esmtpsa
> (Cipher TLSv1:AES256-SHA:256) (Exim 4.50 #1)
> id 1DQYzz-0003WV-Sq by authid <jidanni> with plain; Wed, 27 Apr 2005 04:27:48 +0530
> To: GRASSLIST at baylor.edu
> Cc: grass-bugs at intevation.de
> Subject: v.net.iso: some roads cost, others distance: sorry
> From: Dan Jacobson <jidanni at jidanni.org>
> Date: Wed, 27 Apr 2005 05:00:27 +0800
> Message-ID: <873btd6yok.fsf at jidanni.org>
> MIME-Version: 1.0
> Content-Type: text/plain; charset=us-ascii
> X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
> X-Spam-Level:
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
