[GRASS5] Re: GRASS dissolve
Michael Barton
michael.barton at asu.edu
Wed Apr 27 10:01:01 EDT 2005
Michael,
I also just tried to do a dissolve yesterday and it didn¹t work. It SHOULD
work using v.extract d. I wanted demonstrate dissolve while working with a
student yesterday and it didn¹t work. I simply wanted to dissolve all the
common boundaries in a map, so I didn¹t specify a where clause. However,
nothing was dissolved. I think that it will only dissolve polygons with
common cat value, regardless of whether or not you specify. Try specifying
your range of cat numbers v.extract d cat=1-[n] (where [n] is your max cat
number).
Michael Barton
On 4/26/05 3:57 PM, "Michael Zoldak" <Michael.Zoldak at asu.edu> wrote:
> Dr Barton
> This is mike zoldak at IIS again with another GRASS question. I'm trying to
> dissolve polygon boundaries based on a shared attribute value. Is there some
> trick to doing this very basic GIS operation? I've tried about a hundred
> different permutations (literally) of v.extract and v.reclass and nothing
> seems to come close.
> Mike Zoldak
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20050427/a9b89885/attachment.html
