[GRASS5] nviz and volumes
Markus Neteler
neteler at itc.it
Wed Apr 27 17:17:38 EDT 2005
On Wed, Apr 27, 2005 at 05:16:02PM +0200, Markus Neteler wrote:
> On Sun, Apr 24, 2005 at 05:04:53PM +0000, Bob Covill wrote:
> > Hi Helena, Jáchym,
> > I am away right now and cannot confirm this. But when I last tried the
> > Slovakia volume dataset, I had the same problem (i.e. no volumes displayed).
> > What I discovered wass that the 3D region (g.region) had to be set. Once the
> > 3D region was set I was able to view the volume data.
> > I do not know if this is what is causing the problem.
> Some weeks ago I have fixed the slovakia3d.tar.gz for
> the 3D region (Feb 7 2005, 10:25).
> Jáchym, perhaps you are using an older version of this
> package.
Found it!
The WIND file was still outdated. Now I have done:
cd slovakia3d/PERMANENT
cp DEFAULT_WIND WIND
That's it. Repackaged, uploaded, should work now.
Thanks for reporting.
Markus
