[GRASS5] nviz and volumes
Jaro Hofierka
hofierka at geomodel.sk
Fri Apr 29 12:23:42 EDT 2005
Jachym, the top-bottom resolution in the first case is 1 m (0-1). In
that case you cannot see anything because the zmin value is well above 1 m.
Jaro
Jachym Cepicky wrote:
> if I'm not wrong, I took it from
> http://mpa.itc.it/grasstutor/data_menu2nd.phtml
> the date of the set should be
> -rw-r--r-- 1 jachym jachym 8,9M 2005-02-07 09:11 slovakia3d.tar.gz
> g.region -3p gives
> projection: 0 (x,y)
> zone: 0
> north: 5530000
> south: 5275000
> west: 4186000
> east: 4631000
> top: 1.00000000
> bottom: 0.00000000
> nsres: 500
> nsres3: 500
> ewres: 500
> ewres3: 500
> tbres: 1
> rows: 510
> rows3: 510
> cols: 890
> cols3: 890
> depths: 1
> [Raster MASK present]
> and no volumes are drawen. when I move with the viewpoint, the volume is showen
> like 2D-vector area (not 3D-vector cube).
> when I set the 3D resolution value g.region -d, then it worked
> g.region -d3p
> projection: 0 (x,y)
> zone: 0
> north: 5530000
> south: 5275000
> west: 4186000
> east: 4631000
> top: 3000.00000000
> bottom: 0.00000000
> nsres: 500
> nsres3: 500
> ewres: 500
> ewres3: 500
> tbres: 500
> rows: 510
> rows3: 510
> cols: 890
> cols3: 890
> depths: 6
> I really don't know why :-/
> Jachym
