[GRASS5] Re: [GRASSLIST:6645] is search working?
Kirk R. Wythers
kwythers at umn.edu
Thu Apr 28 11:20:05 EDT 2005
On Apr 28, 2005, at 2:04 AM, Markus Neteler wrote:
> On Wed, Apr 27, 2005 at 10:15:11AM -0500, Kirk R. Wythers wrote:
>> Are the search functions on the user and developer mailing lists
>> working properly?
> Yes, I think so:
> http://grass.itc.it/searchgrass.php
> Search: attributes
> Restrict to: GRASS Developers Mailing list
> -> Documents 1 - 10 of 835 matches.
> Where did you try (URL?). It should be redirected to grass.itc.it.
Thanks Markus. I was going in through the community link, to mailing
lists, then getting directed to:
http://grass.institutoecos.org.br/cgi-bin/htsearch
They seem to have some kind of server issue. I emailed the
administrator about it.
>> I am looking for tips on adding attributes (something
>> like add columns) to existing vector maps (I thought this was a job
>> for
>> v.digit) however, I keep getting the dreaded "no matching articles"
>> returned.
> Search for 'db.execute' :-)
> http://grass.itc.it/grass60/manuals/html60_user/db.execute.html
> Add new column to attribute table:
> echo "ALTER TABLE roads ADD COLUMN length double" | db.execute
> Hope this helps
> Markus
