[GRASS5] cvs2cl.pl: selection by date?
Markus Neteler neteler at itc.it
Mon Aug 1 13:36:29 EDT 2005
I am trying to correctly generate the Changelog file for 6.0.1,
but have these troubles:
cvs2cl.pl -l "-d<'2005-10-03'"
cvs [log aborted]: Can't parse date/time: '2005-10-03'
Problem reading log input (pid/exit/signal/core: 22500/1/0/0)
cvs2cl.pl --version
cvs2cl.pl version 2.59; distributed under the GNU GPL.
cvs --version
Concurrent Versions System (CVS) 1.11.17 (client/server)
Any ideas? I googled around, but found no answer which worked.
Maybe it depends on the server version at Intevation?
Thanks
 Markus
PS: Yes, but before subscribing to the cvs2cl.pl ML, I wanted to
    try here :-)
