[GRASS5] GRASS 6.0.1RC1 released
Markus Neteler neteler at itc.it
Thu Aug 4 04:00:48 EDT 2005
William,
I have fixed both problems in 6.0.1-CVS (so it will go into RC2).
Markus
On Wed, Aug 03, 2005 at 04:10:36PM -0500, William K wrote:
> A couple problems I found (leftover from 6.0.0): GCC 4 (Mac OS 10.4)
> problems
> - imagery/i.cca - the command_keys declaration in globals.h was
> removed in 6.1 CVS but not 6.0.
> - r.grow2 - the abs() function/macro problem that was fixed in 6.1 CVS.
> If you want bug reports to fix these I can do that.
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is an
> illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
