[GRASS5] PATCH: SUBMITTING
Brad Douglas
rez at touchofmadness.com
Fri Aug 5 15:30:14 EDT 2005
On Fri, 2005-08-05 at 14:03 +0100, Paul Kelly wrote:
> On Thu, 4 Aug 2005, Brad Douglas wrote:
> > I rearranged the messaging section of the SUBMITTING file to make it a
> > little easier to read (IMHO).
> Perhaps move the section on how to ensure output goes to stdout after the
> section on G_message(), so that it is only mentioned once. It is a lot
> clearer to say data output should go to stdout, rather than "output that
> could be redirected through a pipe" IMHO---the two explanations could be
> combined and would simplify the description a bit further (but not too
> much).
You're right. Is this better?
Brad Douglas <rez at touchofmadness.com>
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050805/d7b574ab/SUBMIT.bin
