[GRASS5] vector line thickness implemented - was Re: R_line_width()
Bob Covill
bcovill at tekmap.ns.ca
Tue Aug 9 09:05:07 EDT 2005
Hi Huidae,
I have just tried the new line width option and it works great.
Unfortunately I think I have discovered a side-effect from it. If you
draw another line feature after drawing a vector with the width option
it is drawn at whatever width the vector was drawn at. For example if
you draw a vector with width=3 and then draw a grid and barscale (for
example) the grid and barscale are drawn with the same heavy line.
Is it possible to reset the line width at the end of a draw to avoid
this problem?
Bob Covill
Markus Neteler wrote:
> On Tue, Aug 09, 2005 at 01:35:48AM -0500, Huidae Cho wrote:
>>Hi,
>>I added 'int R_line_width(int width)' to the raster library. This
>>changes line width for Draw_line().
>>Huidae Cho
> Hi Huidae,
> this is ABSOLUTELY GREAT! I think we discussed it for years...
> To all: find attached a small screenshot of d.vect using the
> line width feature for the roads map.
> Congratulations,
> Markus
