[GRASS5] vector line thickness implemented - was Re: R_line_width()
Huidae Cho
grass4u at gmail.com
Tue Aug 9 14:02:02 EDT 2005
Hmm, it seems that R_color() has the same problem if it's not called by
the next drawing module. When I commented out R_color() block (lines
139-143) in display/d.grid/main.c, it draws grid lines with the last
color d.vect used.
In terms of consistency, current R_line_width() looks OK. But since it's
new feature, no drawing module takes into account this side effect or
some modules even don't need this feature. For the latter case, it will
be simple to modify d.vect. Check out the latest CVS version.
Thank you.
Huidae Cho
On Tue, Aug 09, 2005 at 10:05:07AM -0300, Bob Covill wrote:
> Hi Huidae,
> I have just tried the new line width option and it works great.
> Unfortunately I think I have discovered a side-effect from it. If you
> draw another line feature after drawing a vector with the width option
> it is drawn at whatever width the vector was drawn at. For example if
> you draw a vector with width=3 and then draw a grid and barscale (for
> example) the grid and barscale are drawn with the same heavy line.
> Is it possible to reset the line width at the end of a draw to avoid
> this problem?
> Bob Covill
> Markus Neteler wrote:
> >On Tue, Aug 09, 2005 at 01:35:48AM -0500, Huidae Cho wrote:
> >>Hi,
> >>I added 'int R_line_width(int width)' to the raster library. This
> >>changes line width for Draw_line().
> >>Huidae Cho
> >Hi Huidae,
> >this is ABSOLUTELY GREAT! I think we discussed it for years...
> >To all: find attached a small screenshot of d.vect using the
> >line width feature for the roads map.
> >Congratulations,
> > Markus
