[GRASS5] Re: [GRASSLIST:7910] grass-6.0.1RC2 compilation
Markus Neteler
neteler at itc.it
Tue Aug 16 16:51:24 EDT 2005
On Mon, Aug 15, 2005 at 03:23:46PM -0400, jun liang wrote:
> I was trying to compile grass-6.0.1RC2 and had the following error log.
> The "./configure " worked before that.
> I guess the problem is due to some libraries' path setting. I am fairly
> new to grass and any help will be appreciated. Thanks.
> ubehebe:</scratch/grass6/grass-6.0.1RC2> make
> mkdir -p /scratch/grass6/grass-6.0.1RC2/bin.sparc-sun-solaris2.9
> /afs/isis/depts/geog/pkg/ipw-1.0/etc/install -c -m 644 ../include/*.h
> /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/include/
I don't see anything offending in above command.
> install -- install commands, libraries, etc.
> Usage: install [-c] [-m mode] [-o owner] [-g group] [-s] file destination
> make[1]: *** [headers] Error 1
The other errors are resulting from above problem.
Does install from sparc-sun-solaris2.9 have problems with wildcards?
Markus
