[GRASS5] monitor resize
Markus Neteler
neteler at itc.it
Sun Aug 21 11:05:07 EDT 2005
On Sat, Aug 20, 2005 at 07:59:07PM -0700, Hamish wrote:
> > I have a question. I remember I was able to resize the XDRIVER
> > monitor by dragging the edge of the window with mouse. But now I
> > cannot, maybe from 6.0 (?). Is this intended (then why?) or a
> > window manager problem?
> It should work. Try with another WM; are you using Fluxbox or something
> more exotic?
Resizing is disabled if you are using an interactive command
such as i.points etc. It get's enabled again once you leave the
command.
Markus
