[GRASS5] monitor resize
Huidae Cho grass4u at gmail.com
Sun Aug 21 16:10:15 EDT 2005
I tried twm, WindowMaker, Fluxbox, evilwm, ion, wmi2, ...
twm, evilwm, wmi2: resizing works
WindowMaker, Fluxbox, ion: resizing doesn't work
It depends on which WM I use.  Does this mean that some WMs ignore the
USSize hint?  Or is the USSize hint supposed to not allow WM to resize the
window?  If this is the latter case, I think XDRIVER should be fixed.
Huidae Cho
On Sat, Aug 20, 2005 at 07:59:07PM -0700, Hamish wrote:
> > I have a question. I remember I was able to resize the XDRIVER
> > monitor by dragging the edge of the window with mouse.  But now I
> > cannot, maybe from 6.0 (?).  Is this intended (then why?) or a
> > window manager problem?
> It should work. Try with another WM; are you using Fluxbox or something
> more exotic?
> Hamish
> ____________________________________________________
> Start your day with Yahoo! - make it your home page
> http://www.yahoo.com/r/hs
