[Qgis-developer] Re: [GRASS5] QGIS GRASS digitizer new crash
Radim Blazek
radim.blazek at gmail.com
Mon Aug 22 05:48:19 EDT 2005
On 8/18/05, Markus Neteler <neteler at itc.it> wrote:
> > Is there a debugging facility in QGIS, such as a compiler option or an
> > environment variable that you could use to gather more information referring
> > to the error?
> Yes, this should help to enable QGIS debug:
> ./configure --help | grep debug
> --enable-debug Enable debuging messages [default=no]
In GRASS plugin/provider is sometimes used:
#if QGISDEBUG > 3
so to get all messages you have to use something like
export CPPFLAGS="-DQGISDEBUG=5"
before configure.
Radim
