[GRASS5] [bug #3526] (grass) Re: [GRASSLIST:7929] Problem using r.in.gdal to import geoTIFF of US NDVI
Request Tracker
grass-bugs at intevation.de
Wed Aug 17 05:43:26 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3526
(cc bugtracker)
On Tue, Aug 16, 2005 at 03:39:45PM -0400, Kenneth Waight wrote:
> I'm using r.in.gdal to import a geoTIFF file of U.S. NDVI data. The
> import is performed, but this message is displayed and the data
> doesn't seem to be projected correctly:
> GRASS_INFO_WARNING(20541,1): Datum
> 'Not_specified_based_on_Authalic_Sphere' not recognised by GRASS and
> no parameters found. Datum transformation will not be possible using
> this projection information.
> Over-riding projection check.
> Proceeding with import...
> CREATING SUPPORT FILES FOR ndvi.2004113.test
> SETTING GREY COLOR TABLE FOR ndvi.2004113.test (8bit, full range)
> It's close but is a few km off when I reproject to a lat-lon grid.
> Here's the dataset information:
> http://glcf.umiacs.umd.edu/data/modis/ndvi/guide.shtml
> U.S.16 day Vegetation Index User Guide
> * Projection: Alber's Equal Area Conic Conformal
> reprojected from native MODIS projection: Sinusoidal
> Central Meridian used was 96d W
> std Parallels of 29d 30' 0" and 45d 30' 0"
> Latitude of Origin is 0d 0' 0"
> Easting & Northing are 0.0000000000 m
> Datum: sphere (a sphere of radius 6370997 m)
> Resolution is 250 meters
> ***NOTE*** - When you load the geotiff, many programs may not
> correctly recognize the datum and report a wrong datum (i.e., WGS
> 1984). THE DATUM IS THE SPHERE USED IN MODIS DATA, WITH A RADIUS OF
> 6370997 METERS!!!
> Any ideas?
I have downloaded such a file and tested with gdalinfo:
gdalinfo US.Albers.2005145.ndvi.tif
Driver: GTiff/GeoTIFF
Size is 21000, 13000
Coordinate System is:
PROJCS["unnamed",
GEOGCS["Unknown datum based upon the Authalic Sphere",
DATUM["Not_specified_based_on_Authalic_Sphere",
SPHEROID["Sphere",6370997,0,
AUTHORITY["EPSG","7035"]],
AUTHORITY["EPSG","6035"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4035"]],
PROJECTION["Albers_Conic_Equal_Area"],
PARAMETER["standard_parallel_1",29.5],
PARAMETER["standard_parallel_2",45.5],
PARAMETER["latitude_of_center",0],
PARAMETER["longitude_of_center",-96],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (-2356750.000000,5769500.000000)
Pixel Size = (250.00000000,-250.00000000)
Metadata:
AREA_OR_POINT=Point
TIFFTAG_SOFTWARE=hdf2geotiff v0.1.5
Corner Coordinates:
Upper Left (-2356750.000, 5769500.000) (128d59'15.31"W, 49d50'21.28"N)
Lower Left (-2356750.000, 2519500.000) (118d30'25.87"W, 21d47'47.16"N)
Upper Right ( 2893250.000, 5769500.000) ( 56d16'50.11"W, 48d 0'54.53"N)
Lower Right ( 2893250.000, 2519500.000) ( 68d37'26.12"W, 20d30'41.05"N)
Center ( 268250.000, 4144500.000) ( 92d52'8.97"W, 38d54'34.96"N)
Band 1 Block=21000x1 Type=Byte, ColorInterp=Gray
Actually I don't understand the phrase "THE DATUM IS THE SPHERE USED IN MODIS DATA,
WITH A RADIUS OF 6370997 METERS!!!" on the GLCF page as the MODIS sphere is
with radius 6371007.181 according to
http://edcdaac.usgs.gov/landdaac/tools/mrtswath/info/ReleaseNotes.pdf
http://s2k.gsfc.nasa.gov/html_pages/groups/sat/modis_land_overview.html
Moreover, 6370997.0 is the Normal Sphere, not the MODIS sphere:
cs2cs -le | grep 6370997
sphere a=6370997.0 b=6370997.0 Normal Sphere (r=6370997)
But who cares, we can only trust the metadata here.
Importing within Spearfish into a new location I can reproduce
the error message:
r.in.gdal in=US.Albers.2005145.ndvi.tif out=ndvi2005145 loc=albers_usa
WARNING: Datum 'Not_specified_based_on_Authalic_Sphere' not recognised by
GRASS and no parameters found. Datum transformation will not be
possible using this projection information.
Restarting GRASS with ther new location, I get
GRASS 6.1.cvs (albers_usa):/tmp > g.proj -p
-PROJ_INFO-------------------------------------------------
name : Albers Equal Area
proj : aea
a : 6370997
es : -inf
lat_1 : 29.5
lat_2 : 45.5
lat_0 : 0
lon_0 : -96
x_0 : 0
y_0 : 0
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : metre
units : metres
meters : 1
GRASS 6.1.cvs (albers_usa):/tmp > g.proj -w
ERROR: Invalid ellipsoid descriptors (a, rf, es or b) in file
This doesn't look good. Apparently fix is needed.
--- Headers Follow ---
>From neteler at itc.it Wed Aug 17 11:43:25 2005
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id CB287101EFD
for <grass-bugs at lists.intevation.de>; Wed, 17 Aug 2005 11:43:25 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
by mail.intevation.de (Postfix) with ESMTP id 77D9636EDE
Received: from mail.itc.it (ns.itc.it [217.77.80.3])
by mail.intevation.de (Postfix) with ESMTP id F332036ED7
for <grass-bugs at intevation.de>; Wed, 17 Aug 2005 11:43:20 +0200 (CEST)
Received: from ntmain.itc.it ([10.0.20.40])
by mail.itc.it (8.12.11/8.12.11) with SMTP id j7H9hIVp004168;
Wed, 17 Aug 2005 11:43:18 +0200
Received: from orchestra.itc.it ([10.0.10.11])
by ntmain.itc.it (SMSSMTP 4.1.5.31) with SMTP id M2005081711431711744
; Wed, 17 Aug 2005 11:43:17 +0200
Received: from thuille.itc.it. (thuille [10.40.0.110])
by orchestra.itc.it (8.12.11/8.12.11) with ESMTP id j7H9hITq030199;
Received: from thuille.itc.it. (localhost.localdomain [127.0.0.1])
by thuille.itc.it. (8.13.1/8.13.1) with ESMTP id j7H9hHST026531;
Received: (from neteler at localhost)
by thuille.itc.it. (8.13.1/8.13.1/Submit) id j7H9hENR026530;
Wed, 17 Aug 2005 11:43:14 +0200
Date: Wed, 17 Aug 2005 11:43:14 +0200
To: Kenneth Waight <ken at meso.com>
Cc: GRASSLIST at baylor.edu, grass-bugs at intevation.de
Subject: Re: [GRASSLIST:7929] Problem using r.in.gdal to import geoTIFF of US NDVI
Message-ID: <20050817094314.GC13041 at thuille.itc.it>
Mail-Followup-To: Kenneth Waight <ken at meso.com>,
References: <1AB3F352-6A23-40D3-9703-5F70575DAF9F at meso.com>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
In-Reply-To: <1AB3F352-6A23-40D3-9703-5F70575DAF9F at meso.com>
User-Agent: Mutt/1.4.1i
X-PGP-Key: http://www.gdf-hannover.de/neteler/markus_gpgkey.asc
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
