[GRASS5] calculating averages on raster map patches?
Glynn Clements
glynn at gclements.plus.com
Tue Aug 23 18:05:45 EDT 2005
Markus Neteler wrote:
> On a 64bit box I get a segfault from r.stats (called by r.average) after this
> message:
> gdb `which r.stats`
> (gdb) r -anC input='areecampione125m,modis_vi250m20010712.250m_16_days_EVI' fs=space
> Program received signal SIGSEGV, Segmentation fault.
> 0x0000000000402c02 in main (argc=1, argv=0x3535323d737065) at main.c:242
> 242 for (i = 0; name = option.cell->answers[i]; i++)
> (gdb) bt full
> #0 0x0000000000402c02 in main (argc=1, argv=0x3535323d737065) at main.c:242
> msg = "r.stats: cats for modis_vi250m20010712.250m_16_days_EVI are either missing or have no explicit label"
> fd = (int *) 0x5090a0
> i = 2
> name = 0xe8 <Address 0xe8 out of bounds>
> mapset = 0x1 <Address 0x1 out of bounds>
> verbose = 1
> raw_data = 1575156072
> with_coordinates = 0
> with_xy = 0
> with_percents = 0
> with_counts = 0
> with_areas = 1
> with_labels = 0
> fmt = '\0' <repeats 19 times>
> range = {min = 1, max = 40, first_time = 0}
> fp_range = {min = -0.247, max = 1, first_time = 0}
> q = {truncate_only = 0, round_only = 0, defaultDRuleSet = 4199435, defaultCRuleSet = 0, infiniteLeftSet = 0,
> infiniteRightSet = 0, cRangeSet = 1569807600, maxNofRules = 0, nofRules = 0, defaultDMin = 2.7108496074642367e-312,
> defaultDMax = 1.2174480074876701e-316, defaultCMin = 4199435, defaultCMax = 0, infiniteDLeft = 0,
> infiniteDRight = 1.1111882213708365e-312, infiniteCLeft = -1786587576, infiniteCRight = 42, dMin = -0.247, dMax = 1, cMin = 1,
> cMax = 255, table = 0x50cdc0, fp_lookup = {vals = 0x3436, rules = 0x0, nalloc = 0, active = 0,
> inf_dmin = 9.0363127466918322e-313, inf_dmax = 1.1111936913593466e-312, inf_min = -1073744856, inf_max = 127}}
> min = 1
> max = 255
> null_set = 1
> dmin = -0.247
> dmax = 1
> module = (struct GModule *) 0xe8
> flag = {A = 0x5089d0, a = 0x508a20, c = 0x508a70, p = 0x508ac0, l = 0x508b10, q = 0x508b60, n = 0x508bb0, N = 0x508c00,
> one = 0x2a95705380, x = 0x508ca0, g = 0x508c50, i = 0x508d90, r = 0x508d40, C = 0x508cf0}
> option = {cell = 0x3535323d737065, fs = 0x508730, nv = 0x5087c0, output = 0x508850, nsteps = 0x508900}
> Any ideas?
Was this compiled without optimisation? If you enable optimisation
(e.g. -O2, which is added by default unless you manually specify
CFLAGS when configuring), output from gdb is often meaningless.
> I just wonder about
> /* open all cell files */
That looks fine to me. It's iterating over all answers until it gets a
null pointer, marking the end of the list.
