[GRASS5] calculating averages on raster map patches?
Brad Douglas
rez at touchofmadness.com
Tue Aug 23 18:29:15 EDT 2005
On Tue, 2005-08-23 at 23:05 +0100, Glynn Clements wrote:
> Was this compiled without optimisation? If you enable optimisation
> (e.g. -O2, which is added by default unless you manually specify
> CFLAGS when configuring), output from gdb is often meaningless.
I thought optimizing with -g or -ggdb is no longer an issue. I see no
documentation to the contrary.
...Nevermind. I just found gdb documentation to the contrary. Updating
C[XX]FLAGS.
Brad Douglas <rez at touchofmadness.com>
