[GRASS5] v.to.rastdir
Helena Mitasova
hmitaso at unity.ncsu.edu
Tue Aug 23 23:59:54 EDT 2005
Brad,
when you are at it, would you be also able to try out v.to.rast with an
option to compute the
direction of the lines (e.g. streams)?
It is in
http://skagit.meas.ncsu.edu/~helena/grasswork/grasscontrib/
v.to.rastdir.tar
Jaro has already updated it to GRASS6, so it just needs to be merged
with any
changes that might have been done since april and try it out. It should
convert
lines to a raster with cell values representing the aspect (or angle
measured from north, I believe).
So for streams that are digitized downstream the angle would represent
flow direction.
There are many applications for this, among them the angle can be used
in r.sim.water and probably
also in r.flow to prescribe flow direction.
Thank you,
Helena
I updated r.carve to GRASS6 and it seems to work rather well.
Is it okay if I add it to CVS?
Brad Douglas <rez at touchofmadness.com>
