[GRASS5] Stars and stripes in raster maps: segfault
Markus Neteler
neteler at itc.it
Fri Aug 26 05:55:59 EDT 2005
today we discovered a severe problem in the internal raster resampling
routine. We copied a map (XY location) at lower resolution with r.mapcalc,
the result was a damaged map which crashes various modules.
See screenshots (small) are here
http://mpa.itc.it/markus/tmp/rastercrash/
In details:
GRASS 6.1.cvs (ortoxy):~ > g.region rast="3075" -p
projection: 0 (x,y)
zone: 0
north: 1076
south: 0
west: 0
east: 1082
nsres: 1
ewres: 1
rows: 1076
cols: 1082
GRASS 6.1.cvs (ortoxy):~ > d.rast 3075
-> screenshot "original.jpg" (see URL above)
GRASS 6.1.cvs (ortoxy):~ > g.region rast="3075" res=10
GRASS 6.1.cvs (ortoxy):~ > r.mapcalc '3075_7res="3075"'
100%
GRASS 6.1.cvs (ortoxy):~ > d.rast 3075_7res
*** glibc detected *** free(): invalid next size (normal): 0x09067ab8 ***
Aborted
-> screenshot "damaged_rmapcalc.jpg" see URL above)
r.out.ascii 3075_7res > /dev/null
*** glibc detected *** free(): invalid next size (normal): 0x098f6948 ***
Aborted
gdb `which r.out.ascii`
(gdb) bt full
#0 0x003f07a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
No symbol table info available.
#1 0x0029a7d5 in raise () from /lib/tls/libc.so.6
#2 0x0029c149 in abort () from /lib/tls/libc.so.6
#3 0x002ce27a in __libc_message () from /lib/tls/libc.so.6
#4 0x002d4abf in _int_free () from /lib/tls/libc.so.6
#5 0x002d4e3a in free () from /lib/tls/libc.so.6
#6 0x001d7ec0 in close_old (fd=6) at closecell.c:137
i = 8
#7 0x001d7cac in G_close_cell (fd=6) at closecell.c:82
No locals.
#8 0x08049d2f in main (argc=2, argv=0xbfe56f54) at main.c:202
out_type = 0
map_type = 0
name = 0x8cebc58 "3075_7res"
mapset = 0x8cebe90 "neteler"
null_str = 0x804a095 "*"
surfer_null_str = "1.70141e+038"
fd = 6
nrows = 108
ncols = 108
dp = 6
width = 10
rc = 0
fp = (FILE *) 0x3985c0
module = (struct GModule *) 0x21ddcc
parm = {map = 0x21dd80, output = 0x8ceba70, dp = 0x8cebac0, width = 0x8cebb10, null = 0x8cebb70}
flag = {noheader = 0x21dd60, surfer = 0x8cebbe0, modflow = 0x8cebc08, int_out = 0x8cebc30}
Using ddd I identified the crash in libgis at:
static int close_old (int fd)
free (FCB.data); <- crash
#6 0x00eddec0 in close_old (fd=7) at closecell.c:137
/hardmnt/thuille0/ssi/software/cvsgrass61/lib/gis/closecell.c:137:3931:beg:0xeddec0
which is called by G_close_cell().
Debugging the d.rast crash, it also crashes in G_close_cell().
We made a test with 6.0 where everything works smoothly. So it seems to be a
recently introduced bug. Or does it have to do with compression? Or size_t?
GRASS 6.1.cvs > pwd
/nfsmnt/mpa_gdata/ssi/BIO/GRASS_DATA/data/ortoxy/cricri/cellhd
cat 3075
proj: 0
zone: 0
north: 1076
south: 0
east: 1082
west: 0
cols: 1082
rows: 1076
e-w resol: 1
n-s resol: 1
format: 0
compressed: 2
Any suggestions?
Markus
