[GRASS5] [bug #3581] (grass) r.to.vect: assign a proper color table to the ouput
Moritz Lennert mlennert at club.worldonline.be
Fri Aug 26 06:07:48 EDT 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3581
> Subject: r.to.vect: assign a proper color table to the ouput
> Platform: GNU/Linux/i386
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: cvs 23.08.05
> r.to.vect fails to assign a colortable to the output raster which would cover the whole data range. Usually only some or none cells are visible on the raster produced by r.to.vect. This is very missleading, at first I thought there was something wrong with my data, but it showed that running r.colors fixed the problem.
r.to.vect creates a vector as output, not a raster.
Moritz
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDDun0rIrMbm76jD8RAh/4AJ9wWxmb72E0mgf9XfN7PSGDfDuJ5wCeMg2Z
xDtiE3nAuw1Ymi2XPbF+k4A=
=36WM
-----END PGP SIGNATURE-----
