[GRASS5] r.le+r.cost
Paolo Cavallini
cavallini at faunalia.it
Fri Aug 26 13:36:02 EDT 2005
Hi all.
I found a couple of problems using 6.1 compiled from CVS:
FIRST
GRASS 6.1.cvs (spearfish60):~ > r.le.setup
OPTION Raster map to use to setup sampling
key:map
required:YES
enter raster map name:
Enter 'list' for a list of existing raster files
Enter 'list -f' for a list with titles
Hit RETURN to cancel request
> landcover
<landcover>
OPTION Vector map to overlay.
key:vect
required:NO
Overlay a vector file? (y/n) [n]
OPTION Site map to overlay.
key:site
required:NO
Overlay a site file? (y/n) [n]
and stops. However, if I close the program (ctrl-c), I get to the next dialog,
and everything goes well.
SECOND:
r.cost input=cost output=cumulative start_rast=start max_cost=0
percent_memory=25
GRASS_INFO_WARNING(17827,1): segment_pagein: No such file or directory
GRASS_INFO_WARNING(17827,2): segment_pagein: No such file or directory
and nothing happens.
Known problems, or something new?
All the best.
pc
Paolo Cavallini
cavallini at faunalia.it cavallini at jabber.org www.faunalia.it
www.faunalia.com
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050826/7327a16c/attachment.bin
