[GRASS5] [bug #3586] (grass) r.proj error: closecell: can't move file
Request Tracker
grass-bugs at intevation.de
Sat Aug 27 12:23:48 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3586
Subject: r.proj error: closecell: can't move file
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 6.0.1
When using r.proj for larger files (cca 300MB+), r.proj ends with this error:
Allocating memory and reading input map... 100%
Projecting... 100%
WARNING: closecell: can't move
/home/fordfrog/data/mapy/cr-jtsk/PERMANENT/.tmp/centaur/11061.1
to null file
/home/fordfrog/data/mapy/cr-jtsk/PERMANENT/cell_misc/landsat_rgb_composite/null
/home/fordfrog/data/mapy/cr-jtsk/PERMANENT/.tmp/centaur/11061.0
to cell file
/home/fordfrog/data/mapy/cr-jtsk/PERMANENT/cell/landsat_rgb_composite
WARNING: unable to find [landsat_rgb_composite] in [PERMANENT]
WARNING: can't write range file for [landsat_rgb_composite in PERMANENT]
Each time I move the files manually (mv <source> <dest>) and they seem to be OK. The filesystem is vfat.
Miroslav ©ulc
-------------------------------------------- Managed by Request Tracker
