[GRASS5] [bug #3586] (grass) r.proj error: closecell: can't move
file
Morten Hulden
morten at untamo.net
Sun Aug 28 13:44:41 EDT 2005
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3586
> Subject: r.proj error: closecell: can't move file
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: 6.0.1
> When using r.proj for larger files (cca 300MB+), r.proj ends with this error:
> Allocating memory and reading input map... 100%
> Projecting... 100%
> WARNING: closecell: can't move
> /home/fordfrog/data/mapy/cr-jtsk/PERMANENT/.tmp/centaur/11061.1
> to null file
> /home/fordfrog/data/mapy/cr-jtsk/PERMANENT/cell_misc/landsat_rgb_composite/null
> /home/fordfrog/data/mapy/cr-jtsk/PERMANENT/.tmp/centaur/11061.0
> to cell file
> /home/fordfrog/data/mapy/cr-jtsk/PERMANENT/cell/landsat_rgb_composite
> WARNING: unable to find [landsat_rgb_composite] in [PERMANENT]
> WARNING: can't write range file for [landsat_rgb_composite in PERMANENT]
> Each time I move the files manually (mv <source> <dest>) and they seem to be OK. The filesystem is vfat.
Except that I can't see why this would happen only for large files I
think the problem is because a Linux Grass version is run with data
files on a vfat file system. We do not check file system types at run
time, only platform at compile time. So something, using link() instead
of CopyFile(), is breaking ?.
If so, not only r.proj is affected.
From closecell.c:
#ifdef __MINGW32__
if ( CopyFile ( FCB.null_temp_name, path, FALSE ) == 0 ) {
#else
if(link (FCB.null_temp_name, path) < 0) {
#endif
sprintf(command, "mv %s %s", FCB.null_temp_name, path);
if(system(command)) {
sprintf(buf,"closecell: can't move %s\nto null file
%s",
G_warning (buf);
stat = -1;
} else {
remove ( FCB.null_temp_name );
} else {
remove ( path );
} /* null_cur_row > 0 */
