[GRASS5] raster category confusion
Markus Neteler neteler at itc.it
Tue Aug 30 02:31:06 EDT 2005
On Mon, Aug 29, 2005 at 09:13:44PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > the more I look into the problems of r.average and friends,
> > the more confused I get.
> > Simple test (Spearfish):
> > g.region n=4925010 s=4924770 w=598380 e=598740 nsres=120 ewres=90 -p
> > r.mapcalc "one=1"
> > r.info -t one
> > datatype=CELL
> What do you get without -t?
I get this:
GRASS 6.1.cvs (spearfish60):~/grass61/scripts/v.rast.stats > r.info  one
 | Layer:    one                            Date: Mon Aug 29 15:32:38 2005    |
 | Mapset:   neteler                        Login of Creator: neteler         |
 | Location: spearfish60                                                      |
 | DataBase: /ssi0/ssi/neteler/grassdata                                      |
 | Title:     ( one )                                                         |
 |   Type of Map:  cell                Number of Categories: 1                |
 |   Data Type:    CELL                                                       |
 |   Rows:         2                                                          |
 |   Columns:      4                                                          |
 |   Total Cells:  8                                                          |
 |        Projection: UTM (zone 13)                                           |
 |            N:    4925010    S:    4924770   Res:   120                     |
 |            E:     598740    W:     598380   Res:    90                     |
 |   Range of data:    min =  1 max = 1                                       |
 |   Data Source:                                                             |
 |   Data Description:                                                        |
 |    generated by r.mapcalc                                                  |
 |   Comments:        |
 |    1        |
GRASS 6.1.cvs (spearfish60):~/grass61/scripts/v.rast.stats > g.gisenv
GISDBASE=/ssi0/ssi/neteler/grassdata
LOCATION_NAME=spearfish60
MAPSET=neteler
GRASS_DB_ENCODING=utf-8
DEBUG=0
MONITOR=x0
GRASS_GUI=text
GRASS 6.1.cvs (spearfish60):~/grass61/scripts/v.rast.stats > locate one| grep spearfish60
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/cell/one
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/cell_misc/one
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/cell_misc/one/null
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/cell_misc/one/range
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/hist/one
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/cellhd/one
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/cats/one
GRASS 6.1.cvs (spearfish60):/hardmnt/thuille0/ssi/grassdata/spearfish60 > find . -name one
./neteler/cell/one
./neteler/cell_misc/one
./neteler/hist/one
./neteler/cellhd/one
./neteler/cats/one
> > r.stats -1 one
> > 120
> > 156
> > 99
> > 100
> > 120
> > 156
> > 99
> > 100
> That's at odds with the "r.mapcalc one=1", and shouldn't have anything
> to do with categories.
Right. Looks a bit ugly.
> Do you have some other mapset in the search path ahead of the current
> mapset?
GRASS 6.1.cvs (spearfish60):/hardmnt/thuille0/ssi/grassdata/spearfish60 > g.mapsets -p
neteler PERMANENT user1
It seems that there is only this single map gives wrong results.
It's a 32bit RHEL4 box.
Markus
