[GRASS5] raster category confusion
Glynn Clements
glynn at gclements.plus.com
Tue Aug 30 18:14:44 EDT 2005
Markus Neteler wrote:
> > Do you have some other mapset in the search path ahead of the current
> > mapset?
> GRASS 6.1.cvs (spearfish60):/hardmnt/thuille0/ssi/grassdata/spearfish60 > g.mapsets -p
> neteler PERMANENT user1
> It seems that there is only this single map gives wrong results.
> It's a 32bit RHEL4 box.
The only thing I can suggest is using a debugger.
