[GRASS5] [bug #3593] (grass) ps.map: placement by map percentage is off
Request Tracker
grass-bugs at intevation.de
Tue Aug 30 10:21:45 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3593
Subject: ps.map: placement by map percentage is off
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: cvs20050830
Using the the below ps.map instruction set (trying to mirror the legend created in d.vect.thematic), I get a weird result as can be seen in http://moritz.homelinux.org/misc/leg.ps.
When using pstoedit to transform the file into skencil format, it becomes obvious that the placement by percentage seems to have some sort of cumulative effect:
http://moritz.homelinux.org/misc/leg_in_skencil.png
"Value range", "Mapped by ...", and "Color" (and to a certain extent the rectangle) all should start at exactly the same x-value. If you look into the ps-file they actually seem to have the same x-coordinate...
Moritz
*********ps.map instructions file***********
paper a4
end
text 1% 95% Thematic map legend for column findic of map molenbeek
end
text 4% 90% Value range: 0.000000 - 21642.000000
end
text 4% 87% Mapped by 8 intervals of 2705.25
end
text 4% 83% Color
end
text 14% 83% Value
end
text 4% 80% ====
end
text 14% 80% ============
end
rectangle 5% 78% 8% 75%
color black
fcolor white
end
text 14% 76% 0 - 2705.25
end
end
-------------------------------------------- Managed by Request Tracker
