Bugtracker: New AREA filter! (was: [GRASS5] Dealing with old bug reports: new GRASS 6 bugtracker?)
Markus Neteler
neteler at itc.it
Wed Aug 31 15:06:10 EDT 2005
Hi Bernhard,
cool!
I have updated all grass6.1 area bugs to grass6 (keep it simple) and
deleted area grass6.1. Also added links to the filtered RT:
http://grass.itc.it/bugtracking/bugreport.html
GRASS 6 bugs only
GRASS 6 wishes only
Now someone will have to check for the remaining bugs/wishes *without*
area indication if they apply to grass6.
Thanks
Markus
On Wed, Aug 31, 2005 at 06:29:12PM +0200, Bernhard Reiter wrote:
> Dear GRASS-Developers and Tester,
> we just added a filter posibility by AREA to the GRASS bugtracker.
> You will see it on the bottom of the page.
> This might help until we can replace the tracker based
> on request-tracker that is showing its age.
> Best,
> Bernhard
> On Wed, Jul 27, 2005 at 04:35:30PM +0200, Bernhard Reiter wrote:
> > On Mon, Jul 25, 2005 at 11:00:22PM +0200, Markus Neteler wrote:
> > > On Mon, Jul 25, 2005 at 12:25:38PM +0200, Bernhard Reiter wrote:
> > > > Technically, if you set up a filter for grass6 bugs, then you are
> > > > not seeing the others.
> > > How to do this? Doesn't this require an "Area" filter which is
> > > not there? Wish: I would like to see "grass6" only.
> > You are right an area filter would be an improvement.
> > For whatever reason I thought we had one.
> > (I'll ask our system administration if we can easily add one.)
