Bugtracker: New AREA filter! (was: [GRASS5] Dealing with old bug reports: new GRASS 6 bugtracker?)
Bernhard Reiter bernhard at intevation.de
Wed Aug 31 12:29:12 EDT 2005
Dear GRASS-Developers and Tester,
we just added a filter posibility by AREA to the GRASS bugtracker.
You will see it on the bottom of the page.
This might help until we can replace the tracker based
on request-tracker that is showing its age.
Best,
	Bernhard
On Wed, Jul 27, 2005 at 04:35:30PM +0200, Bernhard Reiter wrote:
> On Mon, Jul 25, 2005 at 11:00:22PM +0200, Markus Neteler wrote:
> > On Mon, Jul 25, 2005 at 12:25:38PM +0200, Bernhard Reiter wrote:
> > > Technically, if you set up a filter for grass6 bugs, then you are
> > > not seeing the others.
> > How to do this? Doesn't this require an "Area" filter which is
> > not there? Wish: I would like to see "grass6" only.
> You are right an area filter would be an improvement.
> For whatever reason I thought we had one.
> (I'll ask our system administration if we can easily add one.)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050831/cc0e100c/attachment.bin
