[GRASS5] v.external, OGR/OCI and v.in.ogr
Radim Blazek
radim.blazek at gmail.com
Fri Dec 2 03:38:54 EST 2005
The problem is obviously missing FID. Try 2 things
1) remove topo file and try to run d.vect
2) try to add FID column (unique id) to the table
Radim
On 12/2/05, Stephan Holl <holl at gdf-hannover.de> wrote:
> Dear list,
> I tried to import a vector-dataset from Oracle-spatial using the OGR
> OCI-bindings.
> First export the spearfish-rioads to Oracle
> using v.out.ogr, which works OK. ogrinfo gives all information, that
> everything is fine.
> Now I want to reuse the dataset using v.external:
> v.external dsn=OCI:user/pw at ORACLESP out=roads_OCI
> layer=ROADS_SPEARFISH60
> This seems to work OK, also v.db.select roads_OCI gives appropriate
> output.
> But when I try to display the dataset, only one line is shown, but no
> error is given.
> When I reimport it in GRASS using v.in.ogr and display the imported
> dataset, then all lines are shown on the display...
> v.in.ogr -o dsn=OCI:user/pw at ORACLESP out=roads_OCI_import
> layer=ROADS_SPEARFISH60 type=line
> A debugging-Output (DEBUG=5) is copied here[1].
> Thanks for any pointers how to solve this problem.
> Best
> Stephan
> [1]
> http://www.gdf-hannover.de/holl/tmp/output_DEBUG5.dvect_OCI_v.external
> GDF Hannover - Solutions for spatial data analysis and remote sensing
> Hannover Office - Mengendamm 16d - D-30177 Hannover
> Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
> Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
