[GRASS5] R.flow again
Michael Barton
michael.barton at asu.edu
Tue Dec 6 02:37:33 EST 2005
OK, now something even stranger is happening with r.flow.
I just did a script to create a net erosion/deposition map using USPED. I¹ve
tested it on the Spearfish data set. It includes r.flow, running from the
CLI of course.
If I zoom into to a very small area (205x172), it works like a charm. But if
I zoom out a little bit, r.flow bombs with the error below.
If I try the same zoom levels with the CLI for r.flow, it works fine. Both
are actually running r.flow via the CLI. However, the script is started from
a tcltk dialog. Does anyone have any idea what is going on here? This script
is nice to automate a tedious set of calculations.
Michael
Run from CLI only
GRASS 6.1.cvs (spearfish60_valencia):~ > g.region -p
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4921760
south: 4919710
west: 600720
east: 602440
nsres: 10
ewres: 10
rows: 205
cols: 172
GRASS 6.1.cvs (spearfish60_valencia):~ > r.flow elevation.10m at PERMANENT
dsout=test
r.flow Version 13 August 1995, update/fix October 1999
Opening output files...done.
Allocating memory: elevation, aspect, density, e/w distances, quantization
tolerances.
Reading input files: elevation...
Precomputing: tangents, e/w distances, quantization tolerances, interpolated
border elevatio
ns, aspects.
Working...done.
Writing density file...WARNING: 'cell/test' was found in more mapsets (also
found in user1).
done.
Closing files...done.
De-allocating memory...done.
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4923130
south: 4918340
west: 599570
east: 603590
nsres: 10
ewres: 10
rows: 479
cols: 402
dsout=test
tolerances.
border elevatio
ns, aspects.
Working...done.
found in user1).
done.
Run from script at 479x472 (as above) and r.flow bombs with the following
message
tolerances.
border elevatio
ns, aspects.
Working...done.
found in user1).
done.
GRASS 6.1.cvs (spearfish60_valencia):~ > r.usped &
[14] 2283
[13] Exit 1 r.usped
GRASS 6.1.cvs (spearfish60_valencia):~ > too many nested evaluations
(infinite loop?)
(procedure "GlobalVar::exists" line 1)
invoked from within
"GlobalVar::exists $_widget($path,var)"
(procedure "ProgressBar::_modify" line 4)
invoked from within
"ProgressBar::_modify .progress"
("eval" body line 1)
invoked from within
"eval ProgressBar::$cmd .progress $args"
(procedure ".progress" line 1)
invoked from within
"$opt($dlg,progress) _modify"
(procedure "progress" line 7)
invoked from within
"progress $dlg $val"
invoked from within
"if [eof $fh] {
close $fh
} else {
set str [gets $fh]
append str "\n"
if { [fblocked $fh] } { set str [read $fh] }
while {[set idx [string f..."
(procedure "prnout" line 5)
invoked from within
"prnout 1 file16"
Reduce region to 205x172 and run again from same script
Works fine
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20051206/7936d131/attachment.html
