[GRASS5] v.buffer problems...
Radim Blazek radim.blazek at gmail.com
Wed Dec 7 03:23:09 EST 2005
On 12/7/05, Wolf Bergenheim <wolf+grass at bergenheim.net> wrote:
> Hi, list!
> I guess that this is a known issue, but when doing v.buff on lines that
> form a closed shape v.buffer will extend the buffer to the whole
> "inside" as well.
That is correct in  my opinion, buffer for a line is created for both sides.
If the lines represent closed polygons you should convert them to areas.
Radim
> Has anyone had time to investigate why this happens?
> Is there anything I can do to help? I tried to peek at the v.buffer
> code, but I didn't spot the correct place yet.
> --W
> <:3 )---- Wolf Bergenheim ----( 8:>
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
