[GRASS5] [bug #2829] (grass) v.to.db: remove an option and am suddenly out of range
Maciek Sieczka via RT
grass-bugs at intevation.de
Mon Dec 12 06:52:52 EST 2005
This bug still applies.
THIS WORKS:
$ v.to.db -p map=pkt column=cat opt=count
cat|count
1|1
1 categories read from map
0 records selected from table
0 categories read from map exist in selection from table
0 categories read from map don't exist in selection from table
0 records updated/inserted
0 update/insert errors
$ v.to.db -p map=pkt column=cat opt=cat
cat
1
COMBINATION OF BOTH DOESN'T WORK:
$ v.to.db -p map=pkt column=cat opt=cat,count
Error: value <cat,count> out of range for parameter <option>
Legal range: cat,area,compact,perimeter,length,count,coor,sides,query
-------------------------------------------- Managed by Request Tracker
