[GRASS5] [bug #2829] (grass) v.to.db: remove an option and am
suddenly out of range
Wolf Bergenheim
wolf+grass at bergenheim.net
Mon Dec 12 16:46:56 EST 2005
On 12/12/05 13:52, Maciek Sieczka via RT wrote:
> This bug still applies.
[SNIPP]
> COMBINATION OF BOTH DOESN'T WORK:
Maciek are you implying that this should be implemented? If so what
exactly? If a user issues many options to v.select, then at least the
the user also has to supply the columns where the data should be added.
Right? Do you think v.to.db should simply use the column names equal to
the options? That could be a convenient default.
Dan: What did you expect to happen when you issued the command
"v.to.db -p map=largeCat opt=cat,length,count,coor"?
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
