GRASS, GDAL and Postgres problem (was [GRASS5] [bug #3585] (grass) bus error in general/manage modules)
William Kyngesburye
woklist at kyngchaos.com
Mon Dec 12 17:19:16 EST 2005
Any ideas anyone? This is a strang one.
Summary so far:
- Postgres 8.0.x + PostGIS 1.0.x (I've tried a few different combos
of versions up to the recent 8.0.4+1.0.6)
- GDAL 1.3.1 (started in CVS just before the 1.3.0 release), with
Postgres support
- GRASS 6.0.1 and 6.1CVS (up to 05-11-12) with GDAL support
all built with GCC 3.3 on Mac OS 10.3.8
In this combination, g.remove, g.rename and g.copy crash with a bus
error, yet the gdal modules work.
It doesn't affect GCC 4.0 on Mac OS 10.4. This didn't used to happen
with GDAL 1.2.6. Having Postgres support in GRASS or not doesn't affect
If I leave out Postgres support from GDAL, AND rebuild GRASS,
g.remove, g.rename and g.copy work. Just rebuilding GDAL without
Postgres doesn't help, GRASS must be rebuilt as well. AND, if I have
GRASS working with GDAL w/o PG, then rebuild GDAL with PG, and NOT
rebuild GRASS, GRASS still works.
So, GRASS is picking up something from GDAL at build time that is
causing the problem, and it's somehow connected to Postgres.
HELP!
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do
if you ARE a maniacally depressed robot? No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
