[GRASS5] Why is r.to.rast3 missing?
Wolf Bergenheim
wolf+grass at bergenheim.net
Thu Dec 15 15:07:53 EST 2005
On 15/12/05 21:56, Daniel Calvelo wrote:
> It should be r3.to.xxx ; I'd say r3.to.rast; are there many more ways
> to convert r3 to r besides cross-sections?
The traditional way, 3d to DEM?
--Wolf
> Daniel.
> On 12/15/05, Michael Barton <michael.barton at asu.edu> wrote:
>>Can r3.cross.rast get into the CVS too? This is a great tool.
>>I'm name neutral about this as long as I get it right and put it in the menu
>>correctly.
>>However, if I wanted to get philosophical, I'd say that you should name the
>>module with respect to the file type you start with for type conversion
>>within grass. Things starting with raster and converting to something else
>>should be r.to.xxx. Things starting with rast3 should be r3.to.xxx.
>>Currently we have r.to.vect and v.to rast for example.
>>Michael
>>______________________________
>>Michael Barton, Professor of Anthropology
>>School of Human Evolution and Social Change
>>Arizona State University
>>Tempe, AZ 85287-2402
>>USA
>>voice: 480-965-6262; fax: 480-965-7671
>>www: http://www.public.asu.edu/~cmbarton
>>>From: Sören Gebbert <soerengebbert at gmx.de>
>>>Date: Thu, 15 Dec 2005 16:58:51 +0100 (MET)
>>>To: Helena Mitasova <hmitaso at unity.ncsu.edu>
>>>Cc: <michael.barton at asu.edu>, <grass5 at grass.itc.it>
>>>Subject: Re: [GRASS5] Why is r.to.rast3 missing?
>>>Maybe we should rename r3.in.rast to r.to.rast3 and move it into the
>>>grass6/raster directoy,
>>>to prevent name confusions?
>>>btw.:
>>>there is also a module called r3.cross.rast, which produces cross section
>>>raster maps from 3d maps,
>>>at my homepage. Should i rename it to r.cross.rast3?
>>>my homepage:
>>>http://www-pool.math.tu-berlin.de/~soeren/grass/modules/
>>>Soeren
>>>>Michael Barton wrote:
>>>>>Any reason why r.to.rast3 is missing from the normal GRASS distribution?
>>>>it is there - it is called r3.in.rast. I always forget the name too and
>>>>look for it.
>>>>Helena
>>>Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko!
>>>Satte Provisionen f�r GMX Partner: http://www.gmx.net/de/go/partner
>>_______________________________________________
>>grass5 mailing list
>>http://grass.itc.it/mailman/listinfo/grass5
> -- Daniel Calvelo Aros
> grass5 mailing list
<:3 )---- Wolf Bergenheim ----( 8:>
