[GRASS5] Why is r.to.rast3 missing?
Michael Barton
michael.barton at asu.edu
Thu Dec 15 18:08:11 EST 2005
r3.to.rast slices a volume into rasters based on the vertical resolution
value.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Daniel Calvelo <dca.gis at gmail.com>
> Date: Thu, 15 Dec 2005 14:56:32 -0500
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Sören Gebbert <soerengebbert at gmx.de>, Helena Mitasova
> <hmitaso at unity.ncsu.edu>, <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] Why is r.to.rast3 missing?
> It should be r3.to.xxx ; I'd say r3.to.rast; are there many more ways
to
> convert r3 to r besides cross-sections?
Daniel.
On 12/15/05, Michael Barton
> <michael.barton at asu.edu> wrote:
> Can r3.cross.rast get into the CVS too? This
> is a great tool.
> I'm name neutral about this as long as I get it right and
> put it in the menu
> correctly.
> However, if I wanted to get philosophical,
> I'd say that you should name the
> module with respect to the file type you
> start with for type conversion
> within grass. Things starting with raster and
> converting to something else
> should be r.to.xxx. Things starting with rast3
> should be r3.to.xxx.
> Currently we have r.to.vect and v.to rast for
> example.
> Michael
> Michael Barton,
> USA
> voice:
> www:
> > From: Sören Gebbert
> > Date: Thu, 15 Dec 2005 16:58:51 +0100 (MET)
> > To:
> Helena Mitasova <hmitaso at unity.ncsu.edu>
> > Cc: <michael.barton at asu.edu>,
> > Maybe we should rename r3.in.rast to r.to.rast3 and move it into
> the
> > grass6/raster directoy,
> > to prevent name confusions?
> btw.:
> > there is also a module called r3.cross.rast, which produces cross
> section
> > raster maps from 3d maps,
> > at my homepage. Should i rename it
> to r.cross.rast3?
> > my homepage:
> http://www-pool.math.tu-berlin.de/~soeren/grass/modules/
> > Soeren
> >> Michael Barton wrote:
> >>> Any reason why r.to.rast3 is missing from the
> normal GRASS distribution?
> >> it is there - it is called r3.in.rast. I
> always forget the name too and
> >> look for it.
> >> Helena
> > Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko!
> > Satte Provisionen f�r GMX Partner: http://www.gmx.net/de/go/partner
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
> Daniel Calvelo Aros
