[GRASS5] [bug #3910] (grass) v.buffer - creating buffer areas does not work
Request Tracker
grass-bugs at intevation.de
Wed Dec 21 06:52:35 EST 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3910
Subject: v.buffer - creating buffer areas does not work
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 6.1.cvs
I tried to create a new area boundary around a line theme (where the lines describe a closed ring). Thought it would be easy to do it like this:
v.buffer in=ausschnitt out=buff_ausschnitt bufcol=gesamtbr type=boundary
But GRASS won't create a new theme (there is result theme "buff_ausschnitt", but it is not possible to open it: QGIS "The layer is no valid layer and cannot be added to the map").
After that, I tried to first create a line buffer theme (works fine) and then convert it to a area boundary theme using v.type. However, the new area boundary theme does not have the shape of the line buffer theme. The new created polygon fills out the space inside the ring.
Regards,
Wolfgang
-------------------------------------------- Managed by Request Tracker
