[GRASS5] r.example on spearfish60 data
Glynn Clements
glynn at gclements.plus.com
Fri Dec 23 07:31:35 EST 2005
marcos boullón magán wrote:
> Sorry. I'm not sure this is the best place to post this newbie
> question, but maybe you can redirect me to the right list.
> Trying my Grass 6.0.1 under cygwin (compiled by myself) with the most
> basic sample code, (r.example)[1] on the spearfish60 data [2], I
> realized that the input and output raster maps don't match. The basic
> code is a loop G_get_raster_row (...), then G_put_raster_row (...)
> with no transformation, but the raster map "PERMANENT/cell/density",
> size 16853, converts to "user1/cell/d",size 180759, using same region
> parameters. Size x 10!!.
> user> grass spearfish60/user1
> $ g.region ...
> $ r.example input=density output=d
> $ ls -l spearfish60/PERMANENT/cell/density spearfish60/user1/cell/d
> Is this size increment a normal behaviour? Didn't spearfish60 data
> maps optimized for grass 6.0x data formats?
What does:
diff -u PERMANENT/cellhd/density user1/cellhd/d
say?
