[GRASS5] Re: [GRASSLIST:9669] compilation (again) - also: Re: [GRASS5] [bug #3918] (grass) configure syntax error
Markus Neteler
neteler at itc.it
Fri Dec 30 10:17:22 EST 2005
On Fri, Dec 30, 2005 at 04:12:34PM +0100, Paolo Cavallini wrote:
> Markus: great! Thanks a lot.
> Trying again the debian way, I got:
> dpkg-shlibdeps: failure: ldd on
> `debian/libgrass/usr/lib/grass/lib/libgrass_sim.6.1.cvs.so' gave error exit
> status 1
> dh_shlibdeps: command returned error code 256
> make: *** [binary-arch] Error 1
> so it must be something debian-specific. I'll ask the debiangis list.
Good idea since it works the "GRASS way" of compiling.
There will be a fancy Debian flag to see what's going on
using dpkg.
In any case you have the compiled version already. :-)
Markus
> All the best.
> pc
> At 15:42, venerdì 30 dicembre 2005, Markus Neteler has probably written:
> > Ciao Paolo, Pavel,
> > found it! Details below:
> > PS: @Paolo:
> > On Fri, Dec 30, 2005 at 11:31:41AM +0100, Paolo Cavallini wrote:
> > > It worked after several trials, but only removing a couple of modules
> > > (r.sim.water r.sim.sediment).
> > After loggin in, I just compiled the entire on your machine without
> > problems (but I used 'make' instead of the Debian approach to compile).
> > Enjoy!
> Paolo Cavallini
> email+jabber: cavallini at faunalia.it
> www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
