[GRASS5] script posting question (and sorry for earlier offtopic posting)
Michael Barton michael.barton at asu.edu
Fri Dec 30 12:09:31 EST 2005
As Maciek says, I changed r.in.aster recently to match changes in gdal 1.3.1
hdf4 parsing. If you are using an earlier version of gdal (e.g., 1.2.8), you
need the older version of r.in.aster. If you are using the current version
of gdal (1.3.1), you need the most recent cvs version of r.in.aster.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
Date: Thu, 29 Dec 2005 20:06:57 +0100
To: <grass5 at grass.itc.it>
Subject: [GRASS5] script posting question (and sorry for earlier offtopic
posting)
Hello!
I'm planning to make some new script and also some enhancements to the
r.in.aster script,
as I have an aster dataset which seems to be slightly different from what
the current
script could handle /this is also HDF4 but dataset names inside the
file are built up different and maybe projection information is coded
different/ (maybe mine dataset is earlier?)
I'm NOT a C developer, I rather do application level programming, even this
is my job, however
I'm not familiar at all with CVS and others - is it OK if I post some
tips/ideas here?
I'm also planning to make an ARC/INFO workspace importer, to more all less
convert all (older) ARC/INFO
coverages from a workspace by making it as automatical as possible. It could
also be interesting.
Is there a collecting space on the WEB where these utilities/scripts could
be posted, or all well documented
and good scripts are included in the distribution?
thanks
Robert Kuszinger
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20051230/527335c1/attachment.html
