[GRASS5] r.in.aster latest version
RK
hiding at freemail.hu
Fri Dec 30 11:08:56 EST 2005
Hello!
I was testing the r.in.aster script on my aster datasets and found the following problem:
MODULE:r.in.aster v.3 for GRASS 6.0 (2005/11/4)
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/scripts/r.in.aster/
Current directory: [Grass] / grass6 / scripts / r.in.aster
- gdalwarp doesn't recognize the source projection system
- when I specified it manually (-s_srs), it raised an error message that there are no control pints in source file
Down below the line I attached the gdalinfo output of the HDF4 datafile (Aster L1B)
I checked that I have GDAL 1.2.6 installed in my DEBIAN Linux.
I downloaded 1.3.1 sources but during ./configure I was not able to find out what lib* or *-dev
packages should be downloaded to make it support at least GRASS. I was able to make it support HDF4 and even HDF5 and also GeoTIFF which would be enough.
Is it a GDAL problem? Or my dataset is not really what is supported? Projection IS there, UTM, Zone 32, etc...
----------------------------------------- HERE IS GDALINFO OUTPUT -----------------------------------------------
Driver: HDF4/Hierarchical Data Format Release 4
Size is 512, 512
Coordinate System is `'
Metadata:
HDFEOSVersion=HDFEOS_V2.6
IDOFASTERGDSDATAGRANULE=ASTL1B 0104021038540104160082
RECEIVINGCENTER=EDOS
PROCESSINGCENTER=ASTER-GDS
SENSORNAME=VNIR
POINTINGANGLE=8.588000
SETTINGTIMEOFPOINTING=2001-04-02T10:30:48Z
SENSORNAME=SWIR
POINTINGANGLE=8.514000
SETTINGTIMEOFPOINTING=2001-04-02T10:30:47Z
SENSORNAME=TIR
POINTINGANGLE=8.567000
GAIN=01, HGH
GAIN=02, HGH
GAIN=3N, NOR
GAIN=3B, NOR
GAIN=04, NOR
GAIN=05, NOR
GAIN=06, NOR
GAIN=07, NOR
GAIN=08, NOR
GAIN=09, NOR
GEOMETRICDBVERSION=01.02, 2000-10-25
RADIOMETRICDBVERSION=01.02, 2000-11-09
COARSEDEMVERSION=1.00, 1997-09-03, This data is generated from GTOPO30
SCENECLOUDCOVERAGE=40
QUADRANTCLOUDCOVERAGE=51, 51, 30, 29
SOURCEDATAPRODUCT=ASTL1A 0104021038540104150819, 2001-04-15T15:32:08.000Z, PDS
ASTEROPERATIONMODE=OBSERVATION
ASTEROBSERVATIONMODE=VNIR1, ON
ASTEROBSERVATIONMODE=VNIR2, ON
ASTEROBSERVATIONMODE=SWIR, ON
ASTEROBSERVATIONMODE=TIR, ON
PROCESSEDBANDS=01023N3B0405060708091011121314
ASTERSCENEID=194, 84, 7
ORBITNUMBER=6860
RECURRENTCYCLENUMBER=30, 103
FLYINGDIRECTION=DE
SOLARDIRECTION=162.607586, 49.326238
SPATIALRESOLUTION=15, 30, 90
UPPERLEFT=44.885753, 9.422834
UPPERRIGHT=44.740441, 10.345176
LOWERLEFT=44.331189, 9.256467
LOWERRIGHT=44.187293, 10.170564
SCENECENTER=44.537210, 9.798856
SCENEORIENTATIONANGLE=-11.857101
SENSORSHORTNAME=ASTER_VNIR, ASTER_SWIR, ASTER_TIR
IDOFASTERGDSDATABROWSE=ASTL1A 0104021038540104150819B
IMAGEDATAINFORMATION1=4980, 4200, 1
MINANDMAX1=29, 255
MEANANDSTD1=55.502884, 21.716728
MODEANDMEDIAN1=52, 142
NUMBEROFBADPIXELS1=0, 0
CORINTEL1=N/A
CORPARA1=N/A
RESMETHOD1=CC
MPMETHOD1=UTM
PROJECTIONPARAMETERS1=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE1=32
INCL1=0.676000
OFFSET1=-0.676000
CONUNIT1=W/m2/sr/um
IMAGEDATAINFORMATION2=4980, 4200, 1
MINANDMAX2=13, 255
MEANANDSTD2=39.847095, 20.680019
MODEANDMEDIAN2=31, 134
NUMBEROFBADPIXELS2=0, 0
CORINTEL2=N/A
CORPARA2=N/A
RESMETHOD2=CC
MPMETHOD2=UTM
PROJECTIONPARAMETERS2=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE2=32
INCL2=0.708000
OFFSET2=-0.708000
CONUNIT2=W/m2/sr/um
IMAGEDATAINFORMATION3N=4980, 4200, 1
MINANDMAX3N=13, 255
MEANANDSTD3N=59.084030, 20.481691
MODEANDMEDIAN3N=49, 134
NUMBEROFBADPIXELS3N=0, 0
CORINTEL3N=N/A
CORPARA3N=N/A
RESMETHOD3N=CC
MPMETHOD3N=UTM
PROJECTIONPARAMETERS3N=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE3N=32
INCL3N=0.862000
OFFSET3N=-0.862000
CONUNIT3N=W/m2/sr/um
IMAGEDATAINFORMATION3B=4980, 4600, 1
MINANDMAX3B=13, 255
MEANANDSTD3B=74.885216, 24.821001
MODEANDMEDIAN3B=62, 134
NUMBEROFBADPIXELS3B=0, 0
CORINTEL3B=N/A
CORPARA3B=N/A
RESMETHOD3B=CC
MPMETHOD3B=UTM
PROJECTIONPARAMETERS3B=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE3B=32
INCL3B=0.862000
OFFSET3B=-0.862000
CONUNIT3B=W/m2/sr/um
IMAGEDATAINFORMATION4=2490, 2100, 1
MINANDMAX4=8, 225
MEANANDSTD4=47.403790, 12.473525
MODEANDMEDIAN4=45, 116
NUMBEROFBADPIXELS4=0, 0
PROCESSINGFLAG4=0
NUMBEROFMEASUREMENTS4=500
MEASUREMENTPOINTNUMBER4=77
AVERAGEOFFSET4=-2.939440, 0.435952
STANDARDDEVIATIONOFFSET4=0.907165, 0.605230
THRESHOLD4=0.700000, 8.000000, 8.000000, 72.000000
PCTIMAGEMATCH4=62
AVGCORRELCOEF4=0.900000
CTHLD4=-0.020000
CORINTEL4=Corrected Intertelescope Error
CORPARA4=Corrected Parallax Error
RESMETHOD4=CC
MPMETHOD4=UTM
PROJECTIONPARAMETERS4=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE4=32
INCL4=0.217400
OFFSET4=-0.217400
CONUNIT4=W/m2/sr/um
IMAGEDATAINFORMATION5=2490, 2100, 1
MINANDMAX5=12, 203
MEANANDSTD5=36.107468, 9.236425
MODEANDMEDIAN5=33, 107
NUMBEROFBADPIXELS5=0, 0
PROCESSINGFLAG5=0
NUMBEROFMEASUREMENTS5=500
MEASUREMENTPOINTNUMBER5=77
AVERAGEOFFSET5=-2.939440, 0.435952
STANDARDDEVIATIONOFFSET5=0.907165, 0.605230
THRESHOLD5=0.700000, 8.000000, 8.000000, 72.000000
PCTIMAGEMATCH5=62
AVGCORRELCOEF5=0.900000
CTHLD5=-0.020000
CORINTEL5=Corrected Intertelescope Error
CORPARA5=Corrected Parallax Error
RESMETHOD5=CC
MPMETHOD5=UTM
PROJECTIONPARAMETERS5=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE5=32
INCL5=0.069600
OFFSET5=-0.069600
CONUNIT5=W/m2/sr/um
IMAGEDATAINFORMATION6=2490, 2100, 1
MINANDMAX6=10, 252
MEANANDSTD6=38.642193, 11.294487
MODEANDMEDIAN6=35, 131
NUMBEROFBADPIXELS6=0, 0
PROCESSINGFLAG6=0
NUMBEROFMEASUREMENTS6=500
MEASUREMENTPOINTNUMBER6=77
AVERAGEOFFSET6=-2.939440, 0.435952
STANDARDDEVIATIONOFFSET6=0.907165, 0.605230
THRESHOLD6=0.700000, 8.000000, 8.000000, 72.000000
PCTIMAGEMATCH6=62
AVGCORRELCOEF6=0.900000
CTHLD6=-0.020000
CORINTEL6=Corrected Intertelescope Error
CORPARA6=Corrected Parallax Error
RESMETHOD6=CC
MPMETHOD6=UTM
PROJECTIONPARAMETERS6=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE6=32
INCL6=0.062500
OFFSET6=-0.062500
CONUNIT6=W/m2/sr/um
IMAGEDATAINFORMATION7=2490, 2100, 1
MINANDMAX7=10, 226
MEANANDSTD7=34.068729, 9.722114
MODEANDMEDIAN7=32, 118
NUMBEROFBADPIXELS7=0, 0
PROCESSINGFLAG7=0
NUMBEROFMEASUREMENTS7=500
MEASUREMENTPOINTNUMBER7=77
AVERAGEOFFSET7=-2.939440, 0.435952
STANDARDDEVIATIONOFFSET7=0.907165, 0.605230
THRESHOLD7=0.700000, 8.000000, 8.000000, 72.000000
PCTIMAGEMATCH7=62
AVGCORRELCOEF7=0.900000
CTHLD7=-0.020000
CORINTEL7=Corrected Intertelescope Error
CORPARA7=Corrected Parallax Error
RESMETHOD7=CC
MPMETHOD7=UTM
PROJECTIONPARAMETERS7=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE7=32
INCL7=0.059700
OFFSET7=-0.059700
CONUNIT7=W/m2/sr/um
IMAGEDATAINFORMATION8=2490, 2100, 1
MINANDMAX8=9, 255
MEANANDSTD8=31.733629, 10.500892
MODEANDMEDIAN8=29, 132
NUMBEROFBADPIXELS8=0, 0
PROCESSINGFLAG8=0
NUMBEROFMEASUREMENTS8=500
MEASUREMENTPOINTNUMBER8=77
AVERAGEOFFSET8=-2.939440, 0.435952
STANDARDDEVIATIONOFFSET8=0.907165, 0.605230
THRESHOLD8=0.700000, 8.000000, 8.000000, 72.000000
PCTIMAGEMATCH8=62
AVGCORRELCOEF8=0.900000
CTHLD8=-0.020000
CORINTEL8=Corrected Intertelescope Error
CORPARA8=Corrected Parallax Error
RESMETHOD8=CC
MPMETHOD8=UTM
PROJECTIONPARAMETERS8=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE8=32
INCL8=0.041700
OFFSET8=-0.041700
CONUNIT8=W/m2/sr/um
IMAGEDATAINFORMATION9=2490, 2100, 1
MINANDMAX9=3, 227
MEANANDSTD9=32.290894, 9.021663
MODEANDMEDIAN9=30, 115
NUMBEROFBADPIXELS9=0, 0
PROCESSINGFLAG9=0
NUMBEROFMEASUREMENTS9=500
MEASUREMENTPOINTNUMBER9=77
AVERAGEOFFSET9=-2.939440, 0.435952
STANDARDDEVIATIONOFFSET9=0.907165, 0.605230
THRESHOLD9=0.700000, 8.000000, 8.000000, 72.000000
PCTIMAGEMATCH9=62
AVGCORRELCOEF9=0.900000
CTHLD9=-0.020000
CORINTEL9=Corrected Intertelescope Error
CORPARA9=Corrected Parallax Error
RESMETHOD9=CC
MPMETHOD9=UTM
PROJECTIONPARAMETERS9=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE9=32
INCL9=0.031800
OFFSET9=-0.031800
CONUNIT9=W/m2/sr/um
IMAGEDATAINFORMATION10=830, 700, 2
MINANDMAX10=689, 1332
MEANANDSTD10=1042.141602, 64.866806
MODEANDMEDIAN10=1049, 1010
NUMBEROFBADPIXELS10=0, 0
PROCESSINGFLAG10=0
NUMBEROFMEASUREMENTS10=500
MEASUREMENTPOINTNUMBER10=85
AVERAGEOFFSET10=-1.303039, -0.314859
STANDARDDEVIATIONOFFSET10=0.346241, 0.255958
THRESHOLD10=0.700000, 3.000000, 3.000000, 12.000000
CORINTEL10=Corrected Intertelescope Error
CORPARA10=N/A
RESMETHOD10=CC
MPMETHOD10=UTM
PROJECTIONPARAMETERS10=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE10=32
INCL10=0.006882
OFFSET10=-0.006882
CONUNIT10=W/m2/sr/um
IMAGEDATAINFORMATION11=830, 700, 2
MINANDMAX11=739, 1409
MEANANDSTD11=1112.364746, 68.708710
MODEANDMEDIAN11=1116, 1074
NUMBEROFBADPIXELS11=0, 0
PROCESSINGFLAG11=0
NUMBEROFMEASUREMENTS11=500
MEASUREMENTPOINTNUMBER11=85
AVERAGEOFFSET11=-1.303039, -0.314859
STANDARDDEVIATIONOFFSET11=0.346241, 0.255958
THRESHOLD11=0.700000, 3.000000, 3.000000, 12.000000
CORINTEL11=Corrected Intertelescope Error
CORPARA11=N/A
RESMETHOD11=CC
MPMETHOD11=UTM
PROJECTIONPARAMETERS11=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE11=32
INCL11=0.006780
OFFSET11=-0.006780
CONUNIT11=W/m2/sr/um
IMAGEDATAINFORMATION12=830, 700, 2
MINANDMAX12=806, 1494
MEANANDSTD12=1186.125000, 71.204071
MODEANDMEDIAN12=1200, 1150
NUMBEROFBADPIXELS12=0, 0
PROCESSINGFLAG12=0
NUMBEROFMEASUREMENTS12=500
MEASUREMENTPOINTNUMBER12=85
AVERAGEOFFSET12=-1.303039, -0.314859
STANDARDDEVIATIONOFFSET12=0.346241, 0.255958
THRESHOLD12=0.700000, 3.000000, 3.000000, 12.000000
CORINTEL12=Corrected Intertelescope Error
CORPARA12=N/A
RESMETHOD12=CC
MPMETHOD12=UTM
PROJECTIONPARAMETERS12=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE12=32
INCL12=0.006590
OFFSET12=-0.006590
CONUNIT12=W/m2/sr/um
IMAGEDATAINFORMATION13=830, 700, 2
MINANDMAX13=1050, 1791
MEANANDSTD13=1447.504395, 78.982140
MODEANDMEDIAN13=1454, 1420
NUMBEROFBADPIXELS13=0, 0
PROCESSINGFLAG13=0
NUMBEROFMEASUREMENTS13=500
MEASUREMENTPOINTNUMBER13=85
AVERAGEOFFSET13=-1.303039, -0.314859
STANDARDDEVIATIONOFFSET13=0.346241, 0.255958
THRESHOLD13=0.700000, 3.000000, 3.000000, 12.000000
CORINTEL13=Corrected Intertelescope Error
CORPARA13=N/A
RESMETHOD13=CC
MPMETHOD13=UTM
PROJECTIONPARAMETERS13=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE13=32
INCL13=0.005693
OFFSET13=-0.005693
CONUNIT13=W/m2/sr/um
IMAGEDATAINFORMATION14=830, 700, 2
MINANDMAX14=1132, 1860
MEANANDSTD14=1531.452881, 78.525772
MODEANDMEDIAN14=1538, 1496
NUMBEROFBADPIXELS14=0, 0
PROCESSINGFLAG14=0
NUMBEROFMEASUREMENTS14=500
MEASUREMENTPOINTNUMBER14=85
AVERAGEOFFSET14=-1.303039, -0.314859
STANDARDDEVIATIONOFFSET14=0.346241, 0.255958
THRESHOLD14=0.700000, 3.000000, 3.000000, 12.000000
CORINTEL14=Corrected Intertelescope Error
CORPARA14=N/A
RESMETHOD14=CC
MPMETHOD14=UTM
PROJECTIONPARAMETERS14=6378137.000000, 6356752.300000, 0.999600, 0.000000, 0.157080, 0.000000, 500000.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000
UTMZONECODE14=32
INCL14=0.005225
OFFSET14=-0.005225
CONUNIT14=W/m2/sr/um
SHORTNAME=ASTL1B
SIZEMBDATAGRANULE=119.176000
PRODUCTIONDATETIME=2001-04-16T08:25:17.000Z
PLATFORMSHORTNAME=AM-1
INSTRUMENTSHORTNAME=ASTER
WESTBOUNDINGCOORDINATE=9.256467
NORTHBOUNDINGCOORDINATE=44.885753
EASTBOUNDINGCOORDINATE=10.345176
SOUTHBOUNDINGCOORDINATE=44.187293
TIMEOFDAY=103854724000Z
CALENDARDATE=20010402
FUTUREREVIEWDATE=20001225
SCIENCEREVIEWDATE=20001109
QAPERCENTMISSINGDATA=0.102571
QAPERCENTOUTOFBOUNDSDATA=0.102571
QAPERCENTINTERPOLATEDDATA=0.000000
REPROCESSINGACTUAL=not reprocessed
PGEVERSION=03.00R02
PROCESSINGLEVELID=1B
MAPPROJECTIONNAME=Universal Transverse Mercator
Subdatasets:
SUBDATASET_1_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":VNIR_Swath:ImageData1
SUBDATASET_1_DESC=[4200x4980] ImageData1 (8-bit unsigned integer)
SUBDATASET_2_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":VNIR_Swath:ImageData2
SUBDATASET_2_DESC=[4200x4980] ImageData2 (8-bit unsigned integer)
SUBDATASET_3_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":VNIR_Swath:ImageData3N
SUBDATASET_3_DESC=[4200x4980] ImageData3N (8-bit unsigned integer)
SUBDATASET_4_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":VNIR_Swath:ImageData3B
SUBDATASET_4_DESC=[4600x4980] ImageData3B (8-bit unsigned integer)
SUBDATASET_5_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":SWIR_Swath:ImageData4
SUBDATASET_5_DESC=[2100x2490] ImageData4 (8-bit unsigned integer)
SUBDATASET_6_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":SWIR_Swath:ImageData5
SUBDATASET_6_DESC=[2100x2490] ImageData5 (8-bit unsigned integer)
SUBDATASET_7_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":SWIR_Swath:ImageData6
SUBDATASET_7_DESC=[2100x2490] ImageData6 (8-bit unsigned integer)
SUBDATASET_8_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":SWIR_Swath:ImageData7
SUBDATASET_8_DESC=[2100x2490] ImageData7 (8-bit unsigned integer)
SUBDATASET_9_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":SWIR_Swath:ImageData8
SUBDATASET_9_DESC=[2100x2490] ImageData8 (8-bit unsigned integer)
SUBDATASET_10_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":SWIR_Swath:ImageData9
SUBDATASET_10_DESC=[2100x2490] ImageData9 (8-bit unsigned integer)
SUBDATASET_11_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":TIR_Swath:ImageData10
SUBDATASET_11_DESC=[700x830] ImageData10 (16-bit unsigned integer)
SUBDATASET_12_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":TIR_Swath:ImageData11
SUBDATASET_12_DESC=[700x830] ImageData11 (16-bit unsigned integer)
SUBDATASET_13_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":TIR_Swath:ImageData12
SUBDATASET_13_DESC=[700x830] ImageData12 (16-bit unsigned integer)
SUBDATASET_14_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":TIR_Swath:ImageData13
SUBDATASET_14_DESC=[700x830] ImageData13 (16-bit unsigned integer)
SUBDATASET_15_NAME=HDF4_EOS:EOS_SWATH:"/mnt/grass/gisdata/aster/10/pg-PR1B0000-2001041602_082_001":TIR_Swath:ImageData14
SUBDATASET_15_DESC=[700x830] ImageData14 (16-bit unsigned integer)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
