[GRASS5] r.mapcalc question
David Piasecki piasecda at nv.doe.gov
Wed Feb 2 14:14:35 EST 2005
Since I'm relatively new to GRASS, I just ran across the r.mapcalc
command, and I started playing with it for merging image data. I've
tried the following, some which works (but it's annoying) and some
which doesn't work but I'd like to know why. For both, assume the
region is set correctly.
First of all, what works:
r.mapcalc
'calc.red=if(isnull(image0.red),image1.red,if(isnull(image1.red),image0.
red))'
That's great; however, I have 42 images. So I tried some logic...
r.mapcalc 'calc.red=( image0.red || image1.red )'
r.mapcalc 'calc.red=( image0.red + image1.red )'
I think these aren't working because GRASS has a problem evaluating
these expressions since image0.red is null wherever image1.red is not
null. However, no error messages are given. Is there an easier way to
do this than the first command given above?
Thanks,
David
