[GRASS5] CVS module: grass6
Bernhard Reiter
bernhard at intevation.de
Tue Feb 8 08:16:46 EST 2005
On Tue, Feb 08, 2005 at 12:31:26PM +0100, Bernhard Reiter wrote:
> For fresh checkouts: Use module grass6 now.
> For old checkouts: You can continue using grass51,
> no need to do a complete recheck in at this time.
s/recheck in/recheckout/
> We could experiment with scripts changing the CVS/Root file contents.
If you happen to have python 2.3 there is a nice solution called rpl.
I tested the following line on the rpm subdirectory and it worked.
rpl --recursive -xRepository --keep-times grass51 grass6 rpm
Get rpl from any Debian mirror, e.g.:
ftp://ftp.de.debian.org/debian/pool/main/r/rpl/rpl_1.5.1.tar.gz
(You can just execute the python script rpl from the tarball, no
need to fully install it. It probably also works on Windows.)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050208/32d5ce20/attachment.bin
