[GRASS5] 6.0.x CVS
    Bernhard Reiter
    bernhard at intevation.de
    Tue Feb  8 06:31:26 EST 2005
On Fri, Feb 04, 2005 at 11:14:09AM +1300, Hamish wrote:
> > I was thinking
> > 	mv grass51 grass6
> > 	ln -s grass6 grass51
Done now!
CVS access is reenabled.
I switched off grass51 in the viewcvs interface to avoid
showing the same module twice.
I hope links will also be corrected then, because they fail.
For fresh checkouts: Use module grass6 now.
For old checkouts: You can continue using grass51,
no need to do a complete recheck in at this time.
We could experiment with scripts changing the CVS/Root file contents.
Happy hacking,
	Bernhard
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050208/a43cd3ac/attachment.bin
